Rivo Plus
€1 299,00
The Rivo Plus builds on the acclaimed Rivo model, now featuring a dedicated ASIC for enhanced S/PDIF and AES-EBU outputs and upgraded MEMS clocks in the USB HUB IC. This delivers pure digital sound and seamless connectivity for audiophiles.
Includes all Volumio Premium features
De prijs is inclusief verzendkosten, invoerrechten en omzetbelasting.
Gratis bezorging Gemaakt in Florence
Gratis bezorging Gratis bezorging
30 dagen retour 30 dagen retour
Toevoegen aan winkelwagentje... Het item is toegevoegd
OPTIMIZED CLOCK STABILITY
Upgraded MEMS clocks in the USB HUB IC enhance reclocking and signal integrity at the USB DAC port, ensuring superior jitter stability and consistent audio quality
I2S/DSD OVER HDMI CONNECTIVITY ADDED
I2S/DSD over HDMI interface offers optimal sonic performance for some external DACs compared to S/PDIF, AES-EBU, and USB
TOEGEWIJDE STEUN
Eén-op-één ondersteuning om te helpen met alles van set-up tot het oplossen van problemen. Altijd beschikbaar voor jou!
THE ULTIMATE DIGITAL TRANSPORT
The Rivo+ is the enhanced version of our award-winning Rivo digital transport. Engineered based on user feedback, Rivo+ elevates the already excellent qualities of the original.
Key upgrades include a dedicated ASIC for cleaner S/PDIF and AES-EBU outputs, improved MEMS clocks for lower jitter, I2S over HDMI connectivity for compatible high-end DACs, and a 12V trigger to power on/off other components.
If you demand the pinnacle of digital transport performance, the Rivo+ is the solution.
ENHANCED AUDIO VIA I2S/DSD OVER HDMI FOR DISCERNING LISTENERS
The Rivo+ features a dedicated ASIC to generate the S/PDIF and AES-EBU output signals, offloading this crucial task from the CPU. This specialized integrated circuit is designed to produce these digital output signals with uncompromising precision, free from any potential interference or jitter introduced by the main processor.
Powering this dedicated ASIC is a high-quality MEMS (Micro-Electro-Mechanical Systems) clock, which provides an exceptionally stable and low-jitter timing reference. Coupled with low-noise voltage regulators, this enhancement to the RIVO+ ensures the output signals maintain the utmost purity and refinement.
GENIET VAN MUZIEK VAN JE FAVORIETE BRONNEN
Rivo+ lets you stream from your favorite music services
Neem uw inhoud mee van lokale of netwerkschijven en speel internetradio af
ENGINEERED FOR SIGNAL PRECISION
Upgraded MEMS clocks in the USB HUB IC enhance reclocking and signal integrity for Rivo+ especially when connected to the USB DAC port. This delivers exceptional jitter and frequency stability, reducing susceptibility to temperature changes and aging for consistently high-quality audio output.
EENVOUDIGE INSTALLATIE
Met de officiële iOS- en Android-apps van Volumio kun je in een paar minuten aan de slag.
GEMAAKT IN ITALIË
Alle Volumio producten worden met trots ontworpen en geassembleerd in Florence, Italië.
ROON READY
Alle Volumio producten zijn Roon Ready gecertificeerd door Roon Labs. waardoor naadloze integratie met Roon mogelijk is.
MEERDERE CONNECTIVITEITSOPTIES OM TE VERKENNEN
S/PDIF and AES-EBU outputs generated by a dedicated ASIC with low-noise power supply + I2S/DSD over HDMI interface for optimized connection and enhanced audio performance.
VOLUMIO PREMIUM INGEBOUWD
On board, the Rivo+ is the latest version of Volumio – Volumio AI- that incorporates Supersearch an AI-powered search function that is meant to optimize your music discovery.
Volumio OS wordt geleverd met een Multi-room mogelijkheid die een geïntegreerde omgeving creëert met andere Volumio stations in je huis.
IN DE DOOS
  • Volumio Rivo+
  • NFC Information Card
  • 5V, 3A Voeding
Audio
Digital Coaxial S/PDIF
Audio Output, up to PCM 192kHz/24bit and DSD64 via DoP
Digital AES/EBU
Audio Output, up to to PCM 192kHz/24bit and DSD64 via DoP
Digital I2S over HDMI Output
Audio Output, up to PCM 768kHz/32bit and DSD256
USB Output
Audio Output, up to PCM 768kHz/32bit and DSD256 (via USB DAC)
Voeding & connectiviteit
USB DAC-poort
1x USB 2.0
USB
1x USB 3.0, 1x USB 2.0
LAN
Gigabit 10/100/1000M
Draadloze
Wi-Fi 802.11a/b/g/n/ac, 2X2 MIMO met RSDB
Bluetooth
5.0
Extra info
Ondersteunde formaten
DSD, WAV, FLAC, Alac, Aac, Vorbis, Mp3 and others
UPNP DLNA
Renderer met Open Home-ondersteuning
Ondersteunde diensten
Airplay via Shairport Sync, Spotify & Spotify Connect, TIDAL & TIDAL Connect, QOBUZ
Beschikbare plugins
Youtube, Squeezelite, Radio Paradise, Podcasts, Pandora, Fusion DSP, Roon Bridge, Soundcloud, Mixcloud
CPU
Amlogic S905D3, Quad Core 1,9 GHz
RAM
2 GB DDR4
Interne opslag
16 GB EMMC
Voeding
5V, 3A
Ontwerp
Ontwerper
Design Narratives Ltd.
Weegt
2,25 kg
Afmetingen
27x15x5 cm
Gebruikershandleiding
Download Volumio Rivo+ User Manual Below:
Volumio Rivo+ Quick Start Guide Below:
Beoordelingen
